383/440 ditributor #993753
05/16/11 06:48 PM
05/16/11 06:48 PM
michigan
bighughey Offline OP
michigan
trying to put my 440 together and i was wondering,i know my 383 distributor is too short but can i get a shaft from a 440 and just change shafts.also is the motor mount location the same on a 383 as a 440.any help would be greatly aprieciated as there are very few mopar people around here
Re: 383/440 ditributor [Re: bighughey] #993754
05/16/11 08:15 PM
05/16/11 08:15 PM
Happy Birthday RapidRobert  Offline
You're good on the block. Haven't checked shafts side by side but I'd say the odds are very high they're the same exc for the length & I've ground down the shaft/added the notch on a good 440 dist to fit my 451 (B) which let me get a perfect fit w no slop. On yours on the bottom add some 1/2" ID flat washers above the collar/roll pin to get the end play to near zero/clean/lube it inside & if you have your initial finalized it'd let you set the slot length while you are in there and toss the heavy spring w the long loop on one end but you'll still b in/out of there several times (at least) to get it spot on. Holler how it goes for you.
Re: 383/440 ditributor [Re: bighughey] #993755
05/17/11 10:23 AM
05/17/11 10:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Depending on the distributor , yes you can change the shaft from the 383 to the 440 , I have even converted the old chrysler style electronic ... the style before the current units with the adjustable mechanical advance now being sold , from electronic to single point .
