Oval 4-bbl Air Cleaner under Cuda Rallye Hood???? #993704
05/16/11 05:42 PM
05/16/11 05:42 PM
Johnson City, TN
Haney Offline OP
Haney  Offline OP
Johnson City, TN
I have an oval air cleaner that has a 4-bbl baseplate that I would love to use under the stock rallye hood of my 73 Cuda. I bought this off Ebay from a guy who said it would fit and work but it is still too tall. My car has a 440 with a Holley Street Dominator Intake and a 4150 Holley double pumper carb with HP body.
My questions are:
1. Has anyone ever modified one of these steel bases to fit under a stock hood and if so, what mods did you do to make it more of a drop base. Pictures?
2. Does anyone have one they would like to sell that has already been modified?
2. Does anybody sell a repop drop base that will work.
Thanks in advance.....
'69 Barracuda 340 4-speed
'73 Cuda PROJECT
Re: Oval 4-bbl Air Cleaner under Cuda Rallye Hood???? [Re: Haney] #993705
05/16/11 05:46 PM
05/16/11 05:46 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
More than likely you have a 383 unit which is the tallest and most plentiful. You can make it a drop base by cutting off the carb horn completely and attaching it to either a flat base or drop base 14" round air cleaner base. Flat would probably give you all the room you need.
Re: Oval 4-bbl Air Cleaner under Cuda Rallye Hood???? [Re: JohnRR] #993706
05/16/11 07:17 PM
05/16/11 07:17 PM
Johnson City, TN
Haney Offline OP
Haney  Offline OP
Johnson City, TN
That is what I was thinking!!!! Cool.
'73 Cuda PROJECT
Re: Oval 4-bbl Air Cleaner under Cuda Rallye Hood???? [Re: Haney] #993707
05/16/11 07:38 PM
05/16/11 07:38 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I used a sheet of aluminum and a 14" air cleaner base to make mine.
Re: Oval 4-bbl Air Cleaner under Cuda Rallye Hood???? [Re: Azzkikrcuda] #993708
05/16/11 07:39 PM
05/16/11 07:39 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
2
Re: Oval 4-bbl Air Cleaner under Cuda Rallye Hood???? [Re: Azzkikrcuda] #993709
05/16/11 07:41 PM
05/16/11 07:41 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
3
Re: Oval 4-bbl Air Cleaner under Cuda Rallye Hood???? [Re: Azzkikrcuda] #993710
05/16/11 08:10 PM
05/16/11 08:10 PM
BDW Offline
BDW  Offline
That looks awesome, great work!
Re: Oval 4-bbl Air Cleaner under Cuda Rallye Hood???? [Re: Azzkikrcuda] #993711
05/16/11 11:01 PM
05/16/11 11:01 PM
Johnson City, TN
Haney Offline OP
Haney  Offline OP
Johnson City, TN
Awesome! Thanks for the pictures. That is a great idea. I may use a piece of aluminum like you did and then sell the base I have.....or may cut the center out of my base....
Is that a cuda your motor is in?
'73 Cuda PROJECT
Re: Oval 4-bbl Air Cleaner under Cuda Rallye Hood???? [Re: Haney] #993712
05/17/11 02:03 AM
05/17/11 02:03 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
