Re: Overheating issue - highway only!
[Re: 318 Stroker]
#993584
05/16/11 02:20 PM
05/16/11 02:20 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
overheating at speeds indicates a water flow problem typically, because you have MORE than enough air flowing through the radiator at speed.
common problem is the old soft rubber of the hose "sucking shut" and stopping flow through the system, which is why so many have springs inside of them. the wire coil is wrapped around to prevent the rubber from pinching closed under negative pressure.
if you don't have one laying around, an old coat hangar can be cut and molded into shape and slid inside the hose to serve the same purpose, and it's free
**Photobucket sucks**
[Re: 70Cuda383]
#993586
05/16/11 05:01 PM
05/16/11 05:01 PM
Challenger 1
Cincinnati, Ohio
Good advise. Rev the engine and see if the hose is trying to suck closed. If there is no spring in there, you should put one in there. Like what was said, a piece of wire wrapped around a broomstick handle will work just fine.
[Re: Andrewh]
#993587
05/16/11 05:02 PM
05/16/11 05:02 PM
RapidRobert
Make sure (as said) the hose ain't sucking partly shut and the stat is opening all the way (not likely) but check, but the prob is a partly/somewhat clogged rad, not enough (water) flow thru it
