OD 4spd T/hsng....on 69 RR 4spd trans... #993106
05/15/11 07:42 PM
05/15/11 07:42 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Should I have any problems mounting an OD tail housing on the earlier 69 RR 4spd trans.
I need the later T-housing to fit correctly in my 71 RR so the insulator mounting pad is correctly located with the 71 trans mount.
Someone had told me once that there was a design change somewhere in 69 and it may not work?
Re: OD 4spd T/hsng....on 69 RR 4spd trans... [Re: cdp] #993107
05/15/11 11:42 PM
05/15/11 11:42 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Yes the truck/van tail will swap as long as you swap bearings also.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
