Hydraulic lifters in solid lifter engine? #992516
05/15/11 12:03 AM
05/15/11 12:03 AM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Can hydraulic lifters, push rods, and rockers from a 1968 273 engine, drop in to a 1967 solid lifter 273 without any mods? Thanks.
Re: Hydraulic lifters in solid lifter engine? [Re: ragtop] #992517
05/15/11 02:01 AM
05/15/11 02:01 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
yes
Re: Hydraulic lifters in solid lifter engine? [Re: ragtop] #992518
05/15/11 04:14 AM
05/15/11 04:14 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Yes..... But NOT with the solid cam. The lifter type is NOT interchangeable. Hyd. with Hyd, solid with solid. Also, you must use NEW lifters on an old cam. NEVER reuse any lifter unless you return it to the exact same position. The exception is with roller lifters or certain "treated" lifters like those built by Schubeck.
Re: Hydraulic lifters in solid lifter engine? [Re: ragtop] #992519
05/15/11 08:29 AM
05/15/11 08:29 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well you can run solid lifters on a hydraulic cam you just run a tighter lash .004 to .006 according to Crane a few years back when we did that.
Now Hyd on a solid??? still tapered to rotate the lifter, But not sure how it would work this way. A new cam and lifters is cheap then use the pushrods and rockers!
Dirt cheap for summit brand
http://www.summitracing.com/search/Depar...ze/5-2L-318/?Ns
in the long run you are better to get something like this using the 68 pushrods and rockers
http://www.summitracing.com/parts/CCA-K20-222-3/
Re: Hydraulic lifters in solid lifter engine? [Re: Dodgem] #992520
05/15/11 07:52 PM
05/15/11 07:52 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
It is not advised to run hydraulic lifters on a solid lifter camshaft. The clearance ramps on the solid cam will cause the pressure in the high pressure chamber of the hydraulic lifter to rise beyond recommended specifications (the lifter sees that as excessive base circle runout), possible causing lifter failure. Regards, Chase
