440 8 qt pan ???? #992383
05/14/11 07:06 PM
05/14/11 07:06 PM
La Grange, Ky
70rrclone Offline OP
La Grange, Ky
i need to take the 8 qt pan off for a seal change. will it come off w/out pulling the eng?
its a 70 B body w/440 auto.
thanks Shane
Re: 440 8 qt pan ???? [Re: 70rrclone] #992384
05/14/11 07:33 PM
05/14/11 07:33 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Yes,you will have to drop the center link for the steering.
john
Re: 440 8 qt pan ???? [Re: 70rrclone] #992385
05/14/11 07:34 PM
05/14/11 07:34 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
It should.You will probally have to drop the center link and undo the motor mounts to lift the engine some.Thats what I do when dropping the one in my 65 B body.Rocky
Chrysler Firepower
Re: 440 8 qt pan ???? [Re: therocks] #992386
05/14/11 08:56 PM
05/14/11 08:56 PM
La Grange, Ky
La Grange, Ky
great!!! thanks for the info guys
shane
Re: 440 8 qt pan ???? [Re: 70rrclone] #992387
05/14/11 11:44 PM
05/14/11 11:44 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Should. drop the link as stated and it would help if you could raise the engine. It's not so much the deep pan as it is getting the front bolts.
Re: 440 8 qt pan ???? [Re: Mr.Yuck] #992388
05/24/11 10:54 PM
05/24/11 10:54 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
For added measure of insurance, check condition of pickup tube and screen and its' clearance from the sump floor before securing the
pan to the engine.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 440 8 qt pan ???? [Re: HYPER8oSoNic] #992389
05/24/11 11:55 PM
05/24/11 11:55 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Depending on the pan, it might hang up on a crank counterweight, in which case just turn the crank. My SB does that; I put a mark on the balancer so I can turn the crank to the right position beforehand.
