PISTON QUESTION #992316
05/14/11 05:36 PM
05/14/11 05:36 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
I have read on other post that most hate kb pistons. So on a 70 440 hp build back to stock. which pistons would you guys suggest without breaking the bank. looking to stay at 9.5 - 10.5 compression so which ones would you run in a street car?
motor is 40 over std 906 heads
thanks abe
Re: PISTON QUESTION [Re: AB&E] #992317
05/14/11 05:44 PM
05/14/11 05:44 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
kb pistons are fine as long as you follow their specs. many guys were trying to run normal ring gaps, which kb specifically says NOT to because it will pop the top of the pistons off when they get hot, then complained when that happened. what type of piston are you looking for? forged, cast, or hyper?
Re: PISTON QUESTION [Re: Baxter61] #992318
05/14/11 05:46 PM
05/14/11 05:46 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
not real sure I was thinking kbs but maybe trw replacments not real sur I do know kbs are reasonably priced so looking for options most bang for the buck deal
Re: PISTON QUESTION [Re: AB&E] #992319
05/14/11 06:07 PM
05/14/11 06:07 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Not much more to move up to these forged 10.5 to 1 most heads give 10 to 1. Speeed pro forged
http://chucker54.stores.yahoo.net/440comdis20s.html
KB also has forged either way $100 is more than Hyper/sterling pistons
the way to go in MHO.
http://chucker54.stores.yahoo.net/icfopi.html
get the right pin size 1.094 I presume.
Re: PISTON QUESTION [Re: AB&E] #992320
05/14/11 08:05 PM
05/14/11 08:05 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
thanks abe
Hate ? ... that is an awful strong word to use. I would say "avoid" if possible.
BREAK THE BANK ? ...why try and cheap-out on something that is not that much more money and on something that is so hard and expensive to UPgrade to ??
IMO ... IF POSSIBLE .... use cast or forged.
Re: PISTON QUESTION [Re: dOc !] #992321
05/14/11 08:34 PM
05/14/11 08:34 PM
What Doc said, OE MP cast (not other brand cast) pistons are stout as hell. I've (& others) have beat them almost to death & I've yet to see 1 piston fail. ~.003 P/W & that's it if you can get a CH to suit you
Re: PISTON QUESTION [Re: Dodgem] #992322
05/15/11 03:06 PM
05/15/11 03:06 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
yep those are the ones I was thinking about & from mancini. after reading about kb hyps thanks for the help again
Re: PISTON QUESTION [Re: AB&E] #992323
05/15/11 03:11 PM
05/15/11 03:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
No problem at all with KB pistons. Have them in my 63 and my sons Dart. Mine is a 440 and his is a 400 and we run them as hard as you can. 63 has been on the road 4 years and my sons Dart with the 400 over 8 years. You just have to set the ring eng gaps right. Ron
Re: PISTON QUESTION [Re: 383man] #992324
05/15/11 05:26 PM
05/15/11 05:26 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I've used KB's in my Slant for many years with no issues. I've even sprayed them. I open up the ring gaps even more than they suggest and have had no issues.
