WD40 Ok For Hood Hinges?
#990268
05/11/11 07:45 AM
05/11/11 07:45 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
I need to lube the hood hinges on my Challenger and I was wondering if WD40 might have any negative affects on the paint on my hood hinges. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: WD40 Ok For Hood Hinges?
[Re: YO7_A66]
#990269
05/11/11 07:53 AM
05/11/11 07:53 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
it won't hurt the paint at all if it's real paint with hardener in it. spray bomb, I'm not so sure.
I don't know that WD40 is the best for hood hinges though..it's too thin and will drain out in a short time. good for a quick fix, but not long term. I would try a silicone or lithium type grease, something with some more "stick" to it.
**Photobucket sucks**
[Re: YO7_A66]
#990270
05/11/11 07:54 AM
05/11/11 07:54 AM
Posts: 2,826 NY usa
540challenger
NY usa
I sprayed plenty of wd-40 on painted surfaces "i have bad aim" never seen a problem but i would think wd-40 would be too light. Maybe a white lithium grease would do a better job
[Re: 540challenger]
#990271
05/11/11 08:08 AM
05/11/11 08:08 AM
YO7_A66
Indiana
I ran out of the white lithium grease, so this is the reason for the question. I will stop and get some. Thanks for the replies.
[Re: MoparforLife]
#990273
05/11/11 09:27 AM
05/11/11 09:27 AM
Posts: 890 Clarksville, Tennessee
monoptn
mopar addict
mopar addict
Actually WD40 is not meant for a lubricant. It is a water displacer. There are many products out there that will be better for you.
It may not be the appropriate lubricant for the job, but WD40 certainly is a lubricant. Anyone who has ever used it can vouch for that. I bet it gets used 10,000:1 as a lubricant or cleaner before other uses. I love WD40!
Their website states:
What does WD-40 do?
WD-40 fulfills five basic functions: 1. CLEANS: WD-40 gets under dirt, grime and grease to clean. It also dissolves adhesives, allowing easy removal of labels, tape and excess bonding material. 2. DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits. 3. PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts. 4. LUBRICATES: WD-40's lubricating ingredients are widely dispersed and tenaciously held to all moving parts. 5. PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements.
