Re: Ford BB FI on a 440 Mopar
[Re: Jim_Lusk]
#988548
05/09/11 02:04 AM
05/09/11 02:04 AM
Posts: 3,877 Oregon
hooziewhatsit
It should be pretty similar to this, I would think. https://board.moparts.org/ubbthreads/favl...amp;postmarker=Only real issues are making the distributor work (rotor spins opposite directions I believe), and all the other minor details. If you choose a donor engine of the same displacement, I'd think you could almost get away with not needing to customize the ECU.
