Gas coming out of short vent tube on 1968GTX #988211
05/08/11 05:04 PM
05/08/11 05:04 PM
Loganville, Georgia USA
gtxman Offline OP
gtxman  Offline OP
Does anyone have a solution for gas coming out of vent tube after filling tank until about 3/4 tank on Gauge. I will stop, get out and see on pavement a gas stream and gas will drip for a few seconds.
Re: Gas coming out of short vent tube on 1968GTX [Re: gtxman] #988212
05/08/11 06:17 PM
05/08/11 06:17 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Only fill it to 1/2 tank.
Re: Gas coming out of short vent tube on 1968GTX [Re: StealthWedge67] #988213
05/08/11 06:54 PM
05/08/11 06:54 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Attach small hose to vent tube and run to a point higher than any full fuel level point so that fuel will not reach that point and dribble out.
Another choice would be to plug that vent and use a vented gas cap.
Re: Gas coming out of short vent tube on 1968GTX [Re: MoparforLife] #988214
05/09/11 12:26 AM
05/09/11 12:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The vented cap on a 68-70 B body is a bad idea because the filler tube is behind the license plate in the bumper , a fast take off has the gas spilling on the ground behind you.
There are 2 vents on the tank , do you have the short line connected to the right one and is it mounted up high in the shock crossmember ? Is the other vent line open and not clogged ?
Re: Gas coming out of short vent tube on 1968GTX [Re: JohnRR] #988215
05/09/11 08:01 AM
05/09/11 08:01 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
John RR is correct. Are you sure the gas is coming out the end of the vent hose? My 69 Roadrunner came from the factory with a leaking vent tube at the tank due to bad sealing. When I bought my 69 GTX in 1990 it had the same problem, couldn't put in more than half a tank of gas. Ma Mopar fixed my original Roadrunner, and I put a new tank in the GTX.
