Re: Timing cover seal - install
[Re: CUDAJAS]
#987833
05/07/11 11:02 PM
05/07/11 11:02 PM
RapidRobert
I'm assuming old style cover where seal goes in from the rear. Put some sealer in the well OD and smear some vaseline generously around the spring in the seal to keep it from popping off and put something circular/flat on the seal to distribute the load esp as you are driving on the open face of the seal as it goes in backwards and press (best) or drive it in w as few strokes as possible (use a BFH)and a drift centered on the flat/circular piece of stock you use EDIT the felt is not for that, need a descrip/pic of it
