i have a world mega block with casting #T5153843. #987589
05/07/11 12:31 PM
05/07/11 12:31 PM
Pa.
W
wedge123 Offline OP
wedge123  Offline OP
W
Pa.
can anybody tell me if its a ok casting.it came with 4.50 finish bore,has big 12an fitting in front,crossbolted on 4 mains think its last generation,and casted by world.
Re: i have a world mega block with casting #T5153843. [Re: wedge123] #987590
05/07/11 01:32 PM
05/07/11 01:32 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
uhhh... Naawww, those were the bad ones! You better not trust it, Probobly should give it to me to properly dispose of!
Re: i have a world mega block with casting #T5153843. [Re: wedge123] #987591
05/07/11 01:39 PM
05/07/11 01:39 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
5153843 is the casting number. The actual part number is P5153862 (if it's a HEMI). That's a fine block. It's a gray iron block with 4.5" finished hone and it should have bushed lifter bores.
That's a great block for a 572 street engine.
Although these blocks were supposedly ready for assembly, they almost never turned out that way. So plan on doing a line hone and decking. Also check that the number 5 main cap studs are marked with ARP. Early versions of these blocks used cheap Chinese studs for #5 main that just didn't hold up.
Re: i have a world mega block with casting #T5153843. [Re: Mopar_Rich] #987592
05/07/11 01:47 PM
05/07/11 01:47 PM
Pa.
W
wedge123 Offline OP
wedge123  Offline OP
W
Pa.
part # is 5153860,its a wedge,lifter bores arent bushed,didnt know about # 5 studs,thanks for info
Re: i have a world mega block with casting #T5153843. [Re: StealthWedge67] #987593
05/07/11 01:55 PM
05/07/11 01:55 PM
Pa.
W
wedge123 Offline OP
wedge123  Offline OP
W
Pa.
give me your address,i,will send it right away,ha!72 demon chassie car,8.80 154mph 557 ci,bme rod broke,windowed mega block with 30 passes on it,going to buy this other block now.2200.00 new in box.
Re: i have a world mega block with casting #T5153843. [Re: StealthWedge67] #987594
05/07/11 02:02 PM
05/07/11 02:02 PM
Pa.
W
wedge123 Offline OP
wedge123  Offline OP
W
Pa.
i have one windowed with 30 passes,4.440 bore,brand new,russ at indy said its fixable,for a fee.
Re: i have a world mega block with casting #T5153843. [Re: wedge123] #987595
05/07/11 06:24 PM
05/07/11 06:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Check ALL the studs.
Re: i have a world mega block with casting #T5153843. [Re: JohnRR] #987596
05/07/11 07:44 PM
05/07/11 07:44 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I has to replace all the studs on mine!
