indapendent rear sup. for e body? #987252
05/06/11 04:54 PM
05/06/11 04:54 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
didnt someone come out with a kit to bolt one up under a e body?
buddy is wanting to do his e body cuda so any info of any sort would help
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: indapendent rear sup. for e body? [Re: toplescuda] #987253
05/06/11 07:07 PM
05/06/11 07:07 PM
QLD Australia
Keith Black® Offline
QLD Australia
don't know of any independent kits, however unlawfulracing.com make a 4-link (I have the b-body one -top system)
Darren Beale
Keith Black Racing Engines®
Re: indapendent rear sup. for e body? [Re: Keith Black®] #987254
05/06/11 07:32 PM
05/06/11 07:32 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
i thought mcg had(or some mopar mag) a ad about it,was like the new challenger but has beefier axles and made for the muscle cars
was wanting to say it had something to do with mancini?....
1971 charger
Re: indapendent rear sup. for e body? [Re: toplescuda] #987255
05/06/11 07:45 PM
05/06/11 07:45 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
There was a guy who seemed to have pretty well thought out custom designed IRS stuff in Cocoa Beach Fla, "321"?? something. He was small time but seemed to have the bases covered. I toyed with an E body IRS set-up, currently I got a Caddy CTS IRS package on the shelf waiting to be installed, but the center section torque limits are its big drawback, but if I resist 1/4 mile use ?I think it might survive.
http://team321.com/321HotRodIRS/321HotRodIRShome.html
Re: indapendent rear sup. for e body? [Re: jcc] #987256
05/07/11 03:47 AM
05/07/11 03:47 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
What about using the rear setup out of the 1989-1997 Tbirds? They use the 8.8 rear gears and you can even swap in the 2003+ Cobra diffs. Don't know the measurements on the width. Also, these have a 4.25 bolt pattern that can be changed to the 4.5 pattern with the cobra hubs. Just an idea.
Re: indapendent rear sup. for e body? [Re: toplescuda] #987257
05/07/11 11:13 AM
05/07/11 11:13 AM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
Most reproduction Shelby Cobras use the rear from an old Jag. Think the 78-87 XJ6 sedan or the 78-94 XJS coupe. The rear will handle the torque of a V-12, and a 428 side oiler, so I think it could handle probably anything else you could put at it. The minus is FINDING one of these rears- as many have been pulled already!
Also- in the same vein- Look at set ups that are offered for the Shelby Cobra Kit Cars. If they are using the XJ set-up, then I am sure someone is making a bolt-in that is based on it.
The plus is you get Ford bolt spacing- same as Mopar. Not sure of track width, etc...
Hope this helps!
CC.
Re: indapendent rear sup. for e body? [Re: chargincharles] #987258
05/07/11 11:24 AM
05/07/11 11:24 AM
Kirkland, Washington
Pacnorthcuda Offline
427
