727 Input seal ?
#987245
05/06/11 04:44 PM
05/06/11 04:44 PM
Posts: 910 Southern Oregon
toyotajeep
Southern Oregon
Hello,
I put a 440 in my Dart last summer. It leaked a bit of fluid at first. When I got it warm from driving it definately leaked more.
For a variety of reasons it sat for almost a year. Now I am working on it on concrete etc. and it is definately a front seal leak.
I pulled it out and I checked and the difference between the seal and the snout was around .025 or less. It spins quite freely and is borderline loose.
The new seal is more more like .065-.070 or so difference between the snout and the seal.
Are there two different types of seals on 727's?
I want the leak fixed so I can drive it.
Thanks, ROB
1989 Dodge Cummins & 1989 Dodge W-250
Re: 727 Input seal ?
[Re: dOc !]
#987247
05/06/11 04:51 PM
05/06/11 04:51 PM
toyotajeep
Southern Oregon
Yes, thank you for the help. The seal is smaller for sure. They both are tight, but the one that is .075 different feels right. The one that is in there does not, it is too loose.
ROB
[Re: gtx6970]
#987250
05/06/11 05:15 PM
05/06/11 05:15 PM
toyotajeep
Southern Oregon
The seal that I installed had about 1 hour run time on a new transmission with a smooth convertor snout. It spun almost with a finger.
The new ones are way tighter, more like I remember the fit to be.
I think the one that was in there was wrong or just too big on the ID.
