A body spring relocation and 8 1/4 rear
#986986
05/05/11 09:34 PM
05/05/11 09:34 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
I'm building a driver for my 16 year old on a 73 dart 318 three speed and has an 8 1/4. Looking through the archives is a little vague but i want the biggest street tires and wheels I can squeeze in there. what offset on the stock rear should i look for and how big a tire? any advise & pictures are appreciated.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: A body spring relocation and 8 1/4 rear
[Re: mikeysmopars]
#986987
05/05/11 10:24 PM
05/05/11 10:24 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
You're a cool Dad. You should be able to get a 8 1/2" tire in there, if you relocate the springs to the frame rail 10 1/2 to 11 depending on backspace of the wheel. I have 6 1/2 backspace and 10" slicks with about 3/8 clearance on the rolled fender. I still have 1/2" or so on the spring. You can shorten the axle use less backspace and load wider rubber. The 8 1/4 will hold anything he can throw at it with a 318 and LSD's are available.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: DragDart360]
#986988
05/05/11 10:44 PM
05/05/11 10:44 PM
mikeysmopars
fresno ca
Thanks Stick, I thought it should come out to about 6.5 The dart I have is a factoy t3b super blue car but ironically my son wants to paint it white with the stripe and it also has the dart sport hood, I showed him your pic and he went right out side and started working on it!
[Re: mikeysmopars]
#986989
05/06/11 08:43 AM
05/06/11 08:43 AM
DragDart360
South Jersey, NJ
Hey Mikey, How about some pic's
[Re: 1Fast340]
#986992
05/06/11 02:06 PM
05/06/11 02:06 PM
mikeysmopars
fresno ca
Well Thanks, I built a 68 belvedere for my oldest boy and he went to be a Marine so his ride has just been sitting for the last several years. My plan is to for now, Spring Location, Subframe connectors & later put an 8 3/4. That way the foundation is done and he can just use it for High School & Do a small Block stroker when we can. I found The wheels I think will work here on Moparts in the race section. 15x 10 with 6.5 backspace. I'll check it out! Mike
[Re: B Dartman]
#986994
07/11/11 01:22 AM
07/11/11 01:22 AM
mikeysmopars
fresno ca
OK.. update on The Boy's project. The car is painted and looks great, just finished the mini tubs and relocation kit. I was going to leave the 8 1/4 in but a buddy came through with an 8 3/4 and thats mocked up at this point. I'm back to the question of what is the biggest tire and wheel combo that will fit and what offset. I have a bare 15x8 with a 3'' front space and looks like it will barely clear with a tire mounted. I'd like to do a 15x10 but don't want to order wheels without being sure. Rear end is stock length. anyone have pictures and specs? thanks in advance Mike
[Re: mikeysmopars]
#986995
10/14/11 02:15 AM
10/14/11 02:15 AM
mikeysmopars
fresno ca
It took a while but its close to done and it doesnt look it but it has 15x10 7.5" backspace with 295 50 15 goodyears on the back and I have enough room for 3" more rubber. I tried to get 6.5" backspace on the rear but wouldn't go so it looks like stock offset from the side. The Boy can't wait to drive it to school.
