Re: Denso Alternator Conversion- Sensing wire
[Re: jsully]
#986951
05/06/11 12:39 AM
05/06/11 12:39 AM
Posts: 1,090 Saskatchewan, Canada
barracudabob
I'm going through the same thing. On Andy's website, he says to put the sensing wire to the starter relay. Scroll down to near the bottom. http://www.arengineering.com/alternatorbracket/ND_bracket/denso.html On the plug in itself, which terminal are you using for the 12V switched power, the one closer to the passenger side, or the inside one? The outer one is red, and the inner one is green. Thanks, Bob
