anyone use the por 15 engine paint? #986177
05/04/11 06:01 PM
05/04/11 06:01 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Hello, has anyone tried the por 15 engine paint? What did you think? How did you apply it? How did it turn out? Any pics? Thanks http://www.por15.com/ENGINE-ENAMEL/productinfo/EEPA/
Re: anyone use the por 15 engine paint? [Re: 70VcodeCoronetRT] #986178
05/04/11 06:15 PM
05/04/11 06:15 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
works well
Re: anyone use the por 15 engine paint? [Re: 70VcodeCoronetRT] #986179
05/04/11 06:42 PM
05/04/11 06:42 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Good product. I've had it on my motor for 6+ years and it's held up very well. I used the Hemi Orange which tends to be a little less bright if that is what you are after.
I've applied POR15 on several occassions and find that it flows easier when it's humid verus, low humidity which it typically is here in AZ. I've had great results both brushing and spraying. When applied with a cheapie brush, in the right conditions, you would never tell that I had brushed it on, it settled/smoothed out so well.
Re: anyone use the por 15 engine paint? [Re: cruzin] #986180
05/04/11 10:50 PM
05/04/11 10:50 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
brushed on
Re: anyone use the por 15 engine paint? [Re: AdamR] #986181
05/04/11 11:04 PM
05/04/11 11:04 PM
Nebraska
Nebraska
AdamR is that the hemi orange? It looks a little off. Or is it just the pic?
Re: anyone use the por 15 engine paint? [Re: 70VcodeCoronetRT] #986182
05/05/11 08:24 AM
05/05/11 08:24 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Yes its Hemi orange. Its was much pale then anything Ive used in a spray can.
Re: anyone use the por 15 engine paint? [Re: AdamR] #986183
05/05/11 11:02 PM
05/05/11 11:02 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
brush on is much better than spray paint
Re: anyone use the por 15 engine paint? [Re: 70VcodeCoronetRT] #986184
05/06/11 01:40 PM
05/06/11 01:40 PM
crlush Offline
crlush  Offline
Used it on a buddys Ford motor, come out really nice, I sprayed it on, was told at the paint store to thin it out some with zylene, came out pretty nice. A lot cheaper than buying car paint.
Re: anyone use the por 15 engine paint? [Re: crlush] #986185
05/06/11 04:50 PM
05/06/11 04:50 PM
ILLINOIS
V
volaredon Online content
volaredon  Online Content
V
ILLINOIS
I have the POR kit in "318 blue" taht I'm gonna try out over the summer.
Re: anyone use the por 15 engine paint? [Re: volaredon] #986186
05/06/11 11:36 PM
05/06/11 11:36 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
Brushed mine on last fall. Went on without a problem, and looks great!
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: anyone use the por 15 engine paint? [Re: closer9] #986187
05/08/11 10:41 PM
05/08/11 10:41 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
