Exhaust Manifold Question--To Flap,or not to Flap? #985933
05/04/11 09:29 AM
05/04/11 09:29 AM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
Have taken apart and rebuilt rusted counterweight
for Flapper valve in right side Exhaust Manifold.
Am ready to put back together.Question is:should
I put the flapper plate back inside the Manifold
and make It all work like original,or just put the Shaft thru without the Flapper Plate,and weld the shaft to the inside of the manifold with the
Counterweight in the open position always??
Re: To Flap,or not to Flap? [Re: gassy66] #985934
05/04/11 09:41 AM
05/04/11 09:41 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
leave it out.
Re: To Flap,or not to Flap? [Re: moparsquid] #985935
05/04/11 11:09 AM
05/04/11 11:09 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Left mine out, never had a problem or ever noticed it was gone
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Exhaust Manifold Question--To Flap,or not to Flap? [Re: gassy66] #985936
05/04/11 11:18 AM
05/04/11 11:18 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Another one for leaving it out.
Re: Exhaust Manifold Question--To Flap,or not to Flap? [Re: gassy66] #985937
05/04/11 11:20 AM
05/04/11 11:20 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What carb/choke setup and are you blocking the crossover in the intake ?
Re: Exhaust Manifold Question--To Flap,or not to Flap? [Re: ireland383] #985938
05/04/11 11:24 AM
05/04/11 11:24 AM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
For me, I would have to decide whether or not I needed it to warm up faster. With it closed, the exhaust gases go up and across the underside of intake. If you drive it alot in colder weather, you may want to leave it operational, or if you only drive it in a warmer climate, and drivability isn't/won't be a concern.
A True Hybrid: Burns Gas AND Rubber!
Re: Exhaust Manifold Question--To Flap,or not to Flap? [Re: fastnos] #985939
05/04/11 12:06 PM
05/04/11 12:06 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Blocked off the heat crossover and elimintated the flap; have no plan to drive my car when it's cold and don't want to compromise performance.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Exhaust Manifold Question--To Flap,or not to Flap? [Re: DPelletier] #985940
05/04/11 02:17 PM
05/04/11 02:17 PM
Wisconsin
moparkid88 Offline
moparkid88  Offline
Wisconsin
Leave it out, when I first bought my 73 charger i couldnt understand why it felt so doggy, so i took it in and put duals on it, had original single, and the exhaust man said it the flap was locked shut. Sure woke up that ole 318.
Re: Exhaust Manifold Question--To Flap,or not to Flap? [Re: moparkid88] #985941
05/04/11 07:39 PM
05/04/11 07:39 PM
With it out it'll destroy your gas mileage esp in cold weather (if that is a concern) & I'm gathering that it is not. To make it inop might tap the sides for 2 brass pipe plugs so in the future you could return it to OE if desired w some brass bushings plus the shaft/flap is a significant restriction. I am assuming these are HP ex manifolds
Re: Exhaust Manifold Question--To Flap,or not to Flap? [Re: RapidRobert] #985942
05/05/11 08:31 AM
05/05/11 08:31 AM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
Thanks for response!I got some stainless washers,
fitted 'em onto shaft after removing flapper,and
welded washers on each side of shaft up against
inside of Manifold.I now have slight bit of movement to Counterweight,so it looks like everythings as original,but no Flapper.Manifold
is now installed.. Eric @ Rickety Enterprises..
Re: Exhaust Manifold Question--To Flap,or not to Flap? [Re: RapidRobert] #985943
05/06/11 01:40 PM
05/06/11 01:40 PM
DPelletier Offline
DPelletier  Offline
It shouldn't hurt gas mileage at all once the car is warmed up and assuming normal outdoor ambient temperatures.
Not that I care in my case with 4:10's and a motor that will need a mixture of pump gas and race fuel....
Re: Exhaust Manifold Question--To Flap,or not to Flap? [Re: DPelletier] #985944
05/06/11 04:59 PM
05/06/11 04:59 PM
What I was saying is that b 4 it gets warmed up your gas mileage will be destroyed which is imp in some apps
