727 2-3 Shift Overlap Factors? #985816
05/03/11 11:10 PM
05/03/11 11:10 PM
People's Republic of Kali
70runner Offline OP
70runner  Offline OP
I'm at the stage of my 727 rebuild, with transgo TF-2 street kit, 4 pinion planetaries, 3.8 lever - making decisions on front clutch clearance, # springs, whether to use transgo clutch flow restrictor, etc. From what I read, these decisions can all influence 2-3 shift overlap.
Assuming there is no magic formula, is there a set of guidelines which address these (and other?) variables in terms of optimizing the 2-3 shift?
The trans is going behind a mostly stock, street 440-6, 3.23 gears, 70RR.
Re: 727 2-3 Shift Overlap Factors? [Re: 70runner] #985817
05/03/11 11:27 PM
05/03/11 11:27 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
to add ... what type clutches, line-pressure, KD band ?
Re: 727 2-3 Shift Overlap Factors? [Re: dOc !] #985818
05/03/11 11:39 PM
05/03/11 11:39 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
Here is what I did when I just put mine together. I talked to the maker of the valve body and they told me to run 12 springs in front drum and set clutch clearance at .100 with flat snap ring. Was also told to run billet front servo or old style or plug port in servo and stack full of washers to make it solid if it is a later cushioning servo. I have only drove it a little but it shifts great.
Re: 727 2-3 Shift Overlap Factors? [Re: 70runner] #985819
05/04/11 01:58 PM
05/04/11 01:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you decide to use a large number of springs in the front clutch, you're stuck with that decision if you don't like the shift. Using fewer springs and relying on the flow restrictor allows you to tune the shift without having to remove/disassemble the trans.
Re: 727 2-3 Shift Overlap Factors? [Re: John_Kunkel] #985820
05/04/11 04:40 PM
05/04/11 04:40 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
i used 10 springs in mine stock was 8 so i thought ten was a good compromise , i went with billet servos and tf-2 kit car shifted nice and clean 2-3 .
1969 Dodge Charger 1969 Dodge Superbee
Re: 727 2-3 Shift Overlap Factors? [Re: John_Kunkel] #985821
05/08/11 07:27 PM
05/08/11 07:27 PM
70runner Offline OP
70runner  Offline OP
Good point. I went with 10. I installed the TF-2 restrictor to the front clutch. If that doesn't work out I can take it out, tap the hole and install a pipe plug with various size holes.
