Help with pulley and belt routing on 440! #985723
05/03/11 09:28 PM
05/03/11 09:28 PM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
Heres the problem, My power steering belt is hitting the underside of my water pump pulley.
I have a two groove crank pulley, and a single pulley on both my alternator and my PS pump.
I am running one belt from the crank, around the water pump and Alternator. The PS Pump has it's own dedicated belt off of the crank.
So what pulley is the wrong one in my setup??
Thanks!!
Re: Help with pulley and belt routing on 440! [Re: redmist] #985724
05/03/11 09:35 PM
05/03/11 09:35 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
I just had that same problem and solved it by getting the correct crank pully.
Re: Help with pulley and belt routing on 440! [Re: MidPenMopar] #985725
05/03/11 09:36 PM
05/03/11 09:36 PM
MidPenMopar Offline
MidPenMopar  Offline
Re: Help with pulley and belt routing on 440! [Re: MidPenMopar] #985726
05/03/11 09:50 PM
05/03/11 09:50 PM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
BOOM Goes the Dynomite!!!!!!
Yup, just dug my old crank pulley out of the attic, and it is much smaller then the aftermarket one I have on the motor now. Looks like a pulley cleanup and install is in order!
Thanks folks!!
