NE issues with Mancini aluminum WP housings? #985446
05/03/11 02:52 PM
05/03/11 02:52 PM
Missouri
bb74swngr Offline OP
mopar addict
mopar addict
Missouri
I remember a while back a thread describing issues with the 440 source aluminum water pump housing. I couldn't find it with a search. Because of those problems I am considering a Mancini aluminum water pump housing and am wondering if anyone has had any problems with the Mancini brand. The Mopar aluminum housings are more expensive but if they are really that much better, do you think I should get one of them?
Thanks for looking:)
BigBlock 74 Swinger
Re: NE issues with Mancini aluminum WP housings? [Re: bb74swngr] #985447
05/03/11 02:56 PM
05/03/11 02:56 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
MANCINI "brand" ? ... so there are THREE diff castings in the market now ?
Re: NE issues with Mancini aluminum WP housings? [Re: dOc !] #985448
05/03/11 03:00 PM
05/03/11 03:00 PM
Missouri
mopar addict
mopar addict
Missouri
Hey Eric. That's what it looks like on their web site. It lists Mopar and Mancini. If someone else could take a look maybe I'm reading it wrong...I'm old:)
BigBlock 74 Swinger
Re: NE issues with Mancini aluminum WP housings? [Re: bb74swngr] #985449
05/03/11 03:04 PM
05/03/11 03:04 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
bb ...I am asking myself ...
The market I THINK is a little "crowded" with TWO .... now there is three ....
I was ONCE(couple of years ago) thinking about having one done in MAG(to be really uNique) ... but the cost would have been prohibitive.
Re: NE issues with Mancini aluminum WP housings? [Re: dOc !] #985450
05/03/11 03:08 PM
05/03/11 03:08 PM
Missouri
mopar addict
mopar addict
Missouri
Eric, do you know if the 440 source ones are okay now to?
BigBlock 74 Swinger
Re: NE issues with Mancini aluminum WP housings? [Re: bb74swngr] #985451
05/03/11 03:22 PM
05/03/11 03:22 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
IIRC ... they had some restriction in the ports ?
Re: NE issues with Mancini aluminum WP housings? [Re: bb74swngr] #985452
05/03/11 03:29 PM
05/03/11 03:29 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
I did read that some one tested the flow of the Cat housing with the one smaller passage and even though it was smaller flowed fine
Since then 440Source now has a housing with their name on it, changed, not sure if it has the small passage, if it matters anyway.
Then again I read another post about opening up the small passage with a die grinder , an easy job.
All in All I have the small cat housing on my stoker motor with NO overheating problem
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: NE issues with Mancini aluminum WP housings? [Re: moparts] #985453
05/03/11 04:07 PM
05/03/11 04:07 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I have the Cat housing same as the Source housing. Even with the smaller passage it never runs hot. The problem was the old Source water pump. I used a napa replacement with the Cat housing and can't get the car over 180 in traffic on a 100 degree day.
Re: NE issues with Mancini aluminum WP housings? [Re: ireland383] #985454
05/03/11 04:35 PM
05/03/11 04:35 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
The Mancini brand is fine ; nice wide water ports with an excellent pump that has an anti cavitation plate. I use one of their setups on my 572ci pump gas stroker with a milodon high-flow thermostat and it works great.
If anybody wants a 440Source housing cheap just lemme know.
Ron
Re: NE issues with Mancini aluminum WP housings? [Re: firefighter3931] #985455
05/03/11 05:12 PM
05/03/11 05:12 PM
Missouri
mopar addict
mopar addict
Missouri
Ron
Thanks ff3931! I think I will go with the Mancini.
Thank you everyone for your input and kindness:)
Russ.
BigBlock 74 Swinger
Re: NE issues with Mancini aluminum WP housings? [Re: firefighter3931] #985456
05/04/11 01:00 AM
05/04/11 01:00 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Ron
I use the Mancini brand pump and housing also with no problems. They told me it is the same as the Mopar one other then the Mancini name on it and it is cheaper. Ron
