Re: Air Filters???
[Re: OzHemi]
#985318
05/03/11 01:38 AM
05/03/11 01:38 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
What he mentions, that I made for the Torana...it has a air funnel that gets cooler air from behind the grill (I cut a hole through the core support for it)
You can sort of see where it is here..
Yeah, exactly! So does the engine pull out more power with the cool air you are getting from the air funnel?
Re: Air Filters???
[Re: MuuMuu101]
#985319
05/03/11 09:18 PM
05/03/11 09:18 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Re: Air Filters???
[Re: OzHemi]
#985322
05/03/11 10:33 PM
05/03/11 10:33 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I don't have a way to compare, since this is how I built the car from the begining with the LS1. I knew I wanted to do it from the onset basically, of getting cooler air into the engine...just didn't know for sure how I was going to do it until I actually made up the template for the box
I can watch the IAT with my handheld OBDII tool, and would be interesting I guess to compare to a car with just a 'normal' underhood air filter.
It's kind of hard when no one will reply to this thread
Do you think it gives you more power? I was thinking, if I ever get to doing a 6.1L swap if I could do a similar thing with my Dart but separate it into two different air filter boxes. This was the kind of air intake modified from a LS air intake:
