small block camshaft front retainer plate #984964
05/02/11 04:14 PM
05/02/11 04:14 PM
MoPar Offline OP
MoPar  Offline OP
if i'am using the timing chain small sheetmetal oil director (for lack of a better term) do i still use a bolt with a hole thru the center in the top left hole (as you face it) this is for a 73 340.
Re: small block camshaft front retainer plate [Re: MoPar] #984965
05/02/11 05:03 PM
05/02/11 05:03 PM
definitely
Re: small block camshaft front retainer plate [Re: RapidRobert] #984966
05/02/11 07:08 PM
05/02/11 07:08 PM
scratchnfotraction Offline
you can use the drilled bolt and the drip tab for the chain.
it used to be the drilled bolt,then it went to the drip tab with solid bolt.
no reason you cant use both for added oiling of the chain though.
make sure the 2 small oil galley plugs are in the block behind the cam thrust plate,I have seen them get a small hole drilled to help oil the chain also.
IMO,it bleeds to much oil around the plate without the small galley plugs. the chain will get enuff oil from splash and from the drip tab and cut down on windage.
if you really want it to oil the chain,a stock oil cooler uses a hollow fuel pump bolt to return oil back to the pan and spray directly on the chain at full oil psi pressure.
I grab them off police cars when I see them just for that reason and plus it cools the oil.
so..your good with just the drip tab and is the way it would come on a later engine that does not have the drilled bolt for the thrust plate.
Re: small block camshaft front retainer plate [Re: scratchnfotraction] #984967
05/02/11 10:00 PM
05/02/11 10:00 PM
MoPar Offline OP
MoPar  Offline OP
Thanks for the good information guys !! Someday it will run !!
Re: small block camshaft front retainer plate [Re: MoPar] #984968
05/02/11 10:02 PM
05/02/11 10:02 PM
Wanna let it go, I'll get it to run
Re: small block camshaft front retainer plate [Re: RapidRobert] #984969
05/02/11 10:11 PM
05/02/11 10:11 PM
MoPar Offline OP
MoPar  Offline OP
I promised myself and my wife that i would actually finish this one, so i better follow thru.
Re: small block camshaft front retainer plate [Re: MoPar] #984970
05/03/11 09:25 AM
05/03/11 09:25 AM
thats just
