413 timing cover #984918
05/02/11 02:32 PM
05/02/11 02:32 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
Is teh timing cover on a 62 413 motor the same as a 440?
Re: 413 timing cover [Re: TrueTripleX] #984919
05/02/11 03:46 PM
05/02/11 03:46 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
SHOULD be ..
Re: 413 timing cover [Re: dOc !] #984920
05/02/11 04:39 PM
05/02/11 04:39 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Depends on the 440 cover, probably. The boss for the upper alternator bracket (near teh t-stat housing) can be in 2 different locations (about 1" difference?) and there's the passenger vs driver-side neck for the lower radiator hose, too.
Re: 413 timing cover [Re: Fury Fan] #984921
05/02/11 05:23 PM
05/02/11 05:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
neither of those matter to the timing cover , the factory didn't move the timing mark and tab like they did when the smallblock switched sides , I hear it's not easy to time the pass. side rad outlet 440 .
Re: 413 timing cover [Re: JohnRR] #984922
05/02/11 05:31 PM
05/02/11 05:31 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Oops, good catch John, my critical reading skills failed me again. Good thing I'm not a rocket surgeon.
