Anchor motor mounts any good? #984883
05/02/11 02:13 PM
05/02/11 02:13 PM
Louisville, KY.
Scottmon Offline OP
Scottmon  Offline OP
Louisville, KY.
Wifey's 2000 Sebring Jxi munched it's front motor mount. Called a local dealer and the best they could do for the rubber isolator was $131!!!!
So...Rock Auto carries Anchor motor mounts for approx. $7.50 each. Thought I'd roll the dice and buy a front and rear mount. Rear looks like it's going too).
Anyway, if Anchor mounts are a POS should I just cancel the order (and save the labor and cussin' if I have to re-do them later) and hit the pick-n-pull for some decent OEM mounts?
Re: Anchor motor mounts any good? [Re: Scottmon] #984884
05/02/11 03:49 PM
05/02/11 03:49 PM
IMGTX Offline
IMGTX  Offline
IIRC Anchor Motormounts are what Autozone sells.
I use them but they are pretty much a crap shoot. Most are made in India.
Still for $125 difference I would go with the Anchor mounts. You can not be sure you aren't still getting the same one just reboxed and marked up. It happens often.
I lucked out and got Moog bushings in my last set of AZ front end parts.
Re: Anchor motor mounts any good? [Re: Scottmon] #984885
05/02/11 07:20 PM
05/02/11 07:20 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Anchor is a knock off...Pronto in LA used to redistribute them all over the LA Basin. I think I bought one...one time because I worked at the joint...Oil dripped on it and 3 months later it was trash. Spend the extra 10 bucks and go to Napa
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Anchor motor mounts any good? [Re: Pyper70] #984886
05/02/11 08:02 PM
05/02/11 08:02 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
they are all junk I hate to tell you...napa autozone pep boys all made in india in the same factory with everyone elses label on them...if you want quality go to the dealer...but you can buy alot of 8 buck ones and change them out for the 130 price tag mopar gets
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Anchor motor mounts any good? [Re: pnypwr] #984887
05/02/11 08:49 PM
05/02/11 08:49 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Yes you can buy many cheap ones and change them out, but is it worth your time to re-do? They are cheap for a reason.
Carl Kessel
Re: Anchor motor mounts any good? [Re: CKessel] #984888
05/03/11 01:59 AM
05/03/11 01:59 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Do yourself a favor and buy the factory one OR make your own. Like said above NOBODY but the dealer carries quality mounts anymore. And, we're not talking about sub-par, we're talking NO-par. I think the rubber is elephant dung or worse......
