74 Rallye tach adjustment questions #984442
05/01/11 11:31 PM
05/01/11 11:31 PM
Grand Forks, ND
cougar_cat_25 Offline OP
Grand Forks, ND
My tach needle doesn't start to move until my engine rpm is 1500-2000ish. I have it out, apart and see that it has one phillips head adjustment screw. Anyone know which way to turn it and ballpark how much?
Re: 74 Rallye tach adjustment questions [Re: cougar_cat_25] #984443
05/02/11 02:34 AM
05/02/11 02:34 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I hooked up a good aftermarket tach and tried to get it as close to the aftermarket tach as posible concentrating on getting the idle to about 3K close. Still your original will probably not move up as fast and drop down slower and be off at least a couple hundred rpms at around 3K. Good luck
Re: 74 Rallye tach adjustment questions [Re: cougar_cat_25] #984444
05/02/11 10:27 AM
05/02/11 10:27 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I have searched for years on information repairing and calibrating the factory tachometer. I have found no schematics and no information on calibration. I know that they were never very accurate even when they are new. They only had two transistors in a rudimentary amplifier that put out more current with more and more closures on the input. Todays technology is much better.
You might consider changing the innards to a Dashworx electronic version. If you send it to him for the install, he will calibrate it for you for an extra fee.
The state of the art method of calibration is to use a function generator to simulate the open and closing of the points or the reluctor triggering the control module. The frequency of the generator is set to 4000 Hz for 1000RPM (8 cylinder engine)indicated on the tach. Calibrating it to another tach works but is not as accurate. It is like setting your watch to the city hall clock. It is fine if it is accurate but it depends on someone else's accuracy in setting it and how long ago it was set. A stuck clock is right twice a day.
Craig
Re: 74 Rallye tach adjustment questions [Re: denfireguy] #984445
05/02/11 04:00 PM
05/02/11 04:00 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Craig
turn the screw any way it will be evident to which way you need to go, if your racing the car don't go by the stock gauge, or even the stock gauge with modern internals, mine is fine for spirited street driving.
Re: 74 Rallye tach adjustment questions [Re: cougar_cat_25] #984446
05/03/11 12:10 AM
05/03/11 12:10 AM
Grand Forks, ND
Grand Forks, ND
The adjustment screw has about half a rotation stop to stop. Went full counter clockwise to get the needle into the numbers at idle. I can tell it's tired and inaccurate, but it's fun watch anyway. thanks guys
Re: 74 Rallye tach adjustment questions [Re: cougar_cat_25] #984447
05/03/11 09:27 AM
05/03/11 09:27 AM
Western PA
FBryan09 Offline
FBryan09  Offline
Western PA
Along these same lines. I have a 71 GTX with a tach that works part time. I just got it and looked under the dash and there is a second wire spliced into the tach wire. Is there any way this should be? It has been restored and it is a new wiring harness.
thanks
