water pump / timing cover bolts - Small Block #984259
05/01/11 09:34 PM
05/01/11 09:34 PM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
Does anyone offer a black oxide/phosphate water pump / timing cover bolt kit for a small block?
Also looking for a black valve cover bolt kit.
I know mopar offers a chrome bolt kit, but I do not really want chrome.
ARP offeres an entire engine kit is balck, but to much money when I really only need the water pump, timing cover bolts.
Thanks,
Jason
Re: water pump / timing cover bolts - Small Block [Re: CUDAJAS] #984260
05/01/11 11:01 PM
05/01/11 11:01 PM
Union Grove, WI
srw-409 Offline
srw-409  Offline
Union Grove, WI
You can get them from a few different places. I only checked at Mega Parts before responding to your post, but I believe Bill Rolik, RT Specialties and Herbs all have them. Should be able to find a set on ebay as well.
Re: water pump / timing cover bolts - Small Block [Re: srw-409] #984261
05/02/11 09:19 AM
05/02/11 09:19 AM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
I'm not sure who else sells them, But I used an ARP kit a few years ago. Watch out as some of the bolts in the ARP kit will not work on the timing cover. Bolts were either to long or to short. It was a poor kit if you ask me.
