hemi fuel pump block off plate #984253
05/01/11 09:26 PM
05/01/11 09:26 PM
albemarle, NC
dusterbd13 Offline OP
albemarle, NC
ut wont fit, seems like the bolt goles are too wide. we ordered one for the hemi, and it was shipped with a label listinng it as small block/big block mopar/big block chevy
anyone have this problem? im thinking its hitting the block and not allowing it into place, but i want to know if this is common before i go grinding on a new part.
Michael
Michael Crawford CSP 1970 plymouth Duster back under construction: http://www.pro-touring.com/showthread.ph...ouring-makeover 1964 el camino beater shop truck 96403-project-drivabeater-2-0-64-el-camino-this-time
Re: hemi fuel pump block off plate [Re: dusterbd13] #984254
05/02/11 12:23 AM
05/02/11 12:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The bolt spacing is the same as the B/RB , it's hitting the block ...
Re: hemi fuel pump block off plate [Re: dusterbd13] #984255
05/02/11 02:47 PM
05/02/11 02:47 PM
AndyF Offline
AndyF  Offline
Common problem when using a Chevy cover. I had to redesign my Chevy fuel pump covers to fit properly on a BB Mopar. The Mopar block has more material in that area so the cover needs to be smaller. Most vendors just sell the Chevy part and make the customer finish the job.
Re: hemi fuel pump block off plate [Re: AndyF] #984256
05/02/11 06:29 PM
05/02/11 06:29 PM
cut a paper template to fit the machined recess or the gasket if it is a close enough fit & use it to mark where on the blockoff it needs to b ground & w a sanding belt (best) or bench grinder get a perfect shape/fit
