gluing vinyl to glass #984112
05/01/11 04:12 PM
05/01/11 04:12 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
My back inside window trim keeps popping especially in the corners Thought about gluing it. What glue would you recommend? Thanks
Re: gluing vinyl to glass [Re: 70 buzz] #984113
05/01/11 04:25 PM
05/01/11 04:25 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i wouldnt use glue myself. a little spot of rtv sealant should hold it, and is easily removed from both pieces, when needed. you can get black, silver, clear, etc.
Re: gluing vinyl to glass [Re: Golden-Arm] #984114
05/01/11 04:43 PM
05/01/11 04:43 PM
Detroit, MI
GetAwayDriver Offline
Detroit, MI
Agree.. you'll need something with a little "rubberiness" against something as hard/slick as glass. Anything that dries hard will just break off.
