Power Steering Quit Working #984071
05/01/11 02:54 PM
05/01/11 02:54 PM
fury4speed Offline OP
I stopped the Car , turned the Enging off and when I restarted it 10 minutes later there was no power steering , on the way Home 2 miles into th edrive the power steering started working again , full of fluid , never a noise or hard at any time , question is could it be a pressur evalve? dirt in the system , the fluid wa snew 2 years ago , thanks.
Re: Power Steering Quit Working [Re: fury4speed] #984072
05/01/11 03:13 PM
05/01/11 03:13 PM
, Kansas popu.512
Mopardude440 Offline
, Kansas popu.512
im having a similar problem with mine, where i just loose assist while driving in town then it will start working again.
Re: Power Steering Quit Working [Re: Mopardude440] #984073
05/01/11 04:55 PM
05/01/11 04:55 PM
Any suggestions?
Re: Power Steering Quit Working [Re: fury4speed] #984074
05/01/11 08:38 PM
05/01/11 08:38 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I could toss out a few ideas, but it may be best to call a pro. Dick Ross at Firm Feel is a pretty sharp guy.
Re: Power Steering Quit Working [Re: Kern Dog] #984075
05/01/11 09:31 PM
05/01/11 09:31 PM
Toss me some idea's please , thanks.
Re: Power Steering Quit Working [Re: fury4speed] #984076
05/01/11 10:16 PM
05/01/11 10:16 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
sounds like your pump is heading south, I had a vehicle come into work last week did the same thing...except it was a 1 ton truck and they lost the hydroboost for the brakes also...saginaw pump failed
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Power Steering Quit Working [Re: fury4speed] #984077
05/02/11 01:48 AM
05/02/11 01:48 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
In some cases the fluid gets too hot and the pump quits working. I added a power steering cooler to the Charger after this happened.
I had a worn out 71 Chevy truck that had an intermittent power steering "system" What a TURD ! It would ofter fail at low rpms while making U turns. I changed the pump TWICE and the problem persisted. I think in that case, the steering box itself was AFU.
