No Power Steering Assist Sometimes While Driving Slow ? #984006
05/01/11 01:25 PM
05/01/11 01:25 PM
, Kansas popu.512
Mopardude440 Offline OP
, Kansas popu.512
Just Replaced My steering gear on a 69 roadrunner from steer and gear and sometimes driving slow you just loose power steering assist? I know the pump worked great on the old box with no problems? Is that a check vavle problem? Thanks Guys !!
Re: No Power Steering Assist Sometimes While Driving Slow ? [Re: Mopardude440] #984007
05/01/11 04:20 PM
05/01/11 04:20 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
belt too loose? But that usually has noise associated with it. I once had an antifreeze leak that sprayed onto the power steering belt, had no power assist when that happened, belt was slipping so bad.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: No Power Steering Assist Sometimes While Driving Slow ? [Re: GO_Fish] #984008
05/01/11 06:11 PM
05/01/11 06:11 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Is it a Federal p/s pump (round filler neck)? Or saginaw p/s pump.
I've noticed something like that when you make quick turns with a Federal p/s pump. They just don't seem to keep up. I changed to a Saginaw pump and never had issues.
Re: No Power Steering Assist Sometimes While Driving Slow ? [Re: autoxcuda] #984009
05/01/11 06:20 PM
05/01/11 06:20 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Something similar happened to my 80 Mirada with a saginaw pump last year. I would lose assist and sometimes it would puke fluid out the cap.
I took the relief valve out of the back of the pump and found the parts and screen were covered in sludge like stuff. The valve/piston would also catch in the bore. I cleaned it up and used some emery cloth on the valve and it's been fine since.
