Re: Ran Brake Master Cylinder Dry...
[Re: GetAwayDriver]
#983879
05/01/11 12:29 PM
05/01/11 12:29 PM
RapidRobert
Dont know ABS so almost hesitant to throw anything out there which will in all likelyhood just confuse the issue rather than helping solve it but I would bench bleed the M/C (on the vehicle of course) & retry it as the M/C will need to b bled anyhow as a matter of course but as you said most likely a lengthy bubble is downstream by now.
[Re: wicked]
#983883
05/01/11 03:44 PM
05/01/11 03:44 PM
Posts: 1,878 Detroit, MI
GetAwayDriver
Detroit, MI
Took the master off, backside looked dry. For the heck of it, I put it back on to see if I could bench-bleed it. I could not seem to get the air out of it. Friend is off to Autozone in my superior Mopar. Also looked at the wheel cylinders/calipers/hoses. Everything looks clean and dry. If it were leaking from the rear and into the booster, I should suspect engine vacuum would draw the fluid into the engine and burn it. This car has been throwing up either an EGR or O2 sensor code for a long time....
