Distributor oil pump drive #983834
05/01/11 11:24 AM
05/01/11 11:24 AM
NoVa
E
ebodyseast Offline OP
E
NoVa
Want to oil an engine by priming the oil pump with a Mopar hex drive rod - any tips on how to remove the oil pump gear drive in a BB, does the intake manifold HAVE to come off? Thanks Moparts
Re: Distributor oil pump drive [Re: ebodyseast] #983835
05/01/11 11:26 AM
05/01/11 11:26 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You do not need to pull the intake, just the distributor and drive gear, use a long flat blade screwdriver, put it in the drive gear slot and turn it CW, once it's up out of the cam gear you might need a long needlenose pliers to pull it out. Some times you can just wedge the screwdriver enough to pull, sometimes you need the pliers.
Don't be the exception.
Re: Distributor oil pump drive [Re: Supercuda] #983836
05/01/11 11:45 AM
05/01/11 11:45 AM
NoVa
E
E
NoVa
Thanks for the great tip Supercuda, sure do appreciate you..
