69 Air Grabber Help #983381
04/30/11 09:54 PM
04/30/11 09:54 PM
Anonymous OP
Anonymous OP
1.)Does anyone know where to get the correct bolts for the air grabber to seal?
2.)Are they not #8 x 3/4 long with a .625 loose washer and zinc plated?
3.)I have yet to find the bolts for this area, I see therammann has a kit but is that for the air grabber to seal mounting?
Annyones help would be appreciated!
Thnaks
Michael
Re: 69 Air Grabber Help [Re: ] #983382
05/02/11 11:35 PM
05/02/11 11:35 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Try Tom Race @ RT Specialties. He has the correct fastener for everything Mopar.
Re: 69 Air Grabber Help [Re: mercman1] #983383
05/03/11 04:05 AM
05/03/11 04:05 AM
Anonymous OP
Anonymous OP
He never answers the phone or returns phone calls. It's time to move on from that guy!
Re: 69 Air Grabber Help [Re: ] #983384
05/03/11 10:18 AM
05/03/11 10:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Contact member gtx6970 ... Bill Alphin, A+M Hightech ... , he probably has them .
Re: 69 Air Grabber Help [Re: mercman1] #983385
05/03/11 10:49 AM
05/03/11 10:49 AM
Chicago, IL
sixpkrt Offline
sixpkrt  Offline
Chicago, IL
I got mine from RT Specialties about a month ago. He answered when I called, and thought he was fine to deal with. I'd give him another try. The N96 seal and retainer clips he has is quality stuff.
1970 Dodge Coronet R/T
Re: 69 Air Grabber Help [Re: ] #983386
05/03/11 10:59 AM
05/03/11 10:59 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
A 100% correct hardware doesn't exist ( as far as I know )This the best I can do ( washer size on these are .75" od)
I pulled a complete setup off a 1969 Roadrunner just maybe 2 or 3 years ago, and all the hardware was black phosphate. Thus why I put kits together this way .
And I've seen the clear zinc plated stuff, but every one was on a restored car. So I can't say for sure if it's correct as well or not.
Seal to box kit
Re: 69 Air Grabber Help [Re: gtx6970] #983387
05/03/11 11:01 AM
05/03/11 11:01 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
airbox to hood kit - 1969 only
Re: 69 Air Grabber Help [Re: gtx6970] #983388
05/03/11 11:01 AM
05/03/11 11:01 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1970 Dodge only
Re: 69 Air Grabber Help [Re: gtx6970] #983389
05/03/11 11:08 AM
05/03/11 11:08 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bill what is not 100% correct ?
