94 Jeep Wrangler runs rough after hot restart #983162
04/30/11 12:20 PM
04/30/11 12:20 PM
Baltimore, MD
MadMax58 Offline OP
MadMax58  Offline OP
Baltimore, MD
I have a 94 Jeep Wrangler 4.0, that only runs rough after hot restart. After a few minutes of driving it starts to run smooth again. It runs fine when started after the engine cools off or when starting after sitting overnight. There are no computer codes, fuel pressure is good, cap, rotor, wires, spark plugs, air filter, are all in good condition. I have have been using lucas fuel injection cleaner in the last several tank fills. Could I have a bad fuel injector that could be leaking fuel in to a cylinder after my engine is shut off?
Re: 94 Jeep Wrangler runs rough after hot restart [Re: MadMax58] #983163
04/30/11 08:00 PM
04/30/11 08:00 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
A leaking injector is a possibility. The 4 liters in the late 90s had hot start issues. there is a TSB to put covers in the injectors and/ or a heat shield to prevent vapor lock.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
