Re: Holley Accelerator Pump Hydrolock
[Re: Hotlumpy]
#982624
04/29/11 05:53 PM
04/29/11 05:53 PM
Posts: 1,567 Ky
jt4406
Ky
Make sure the bowl gasket is installed correctly (accl passage on the correct side), fooled me once! jess
Yeah, it's hopped up to over 160...
[Re: dartman366]
#982627
04/29/11 06:57 PM
04/29/11 06:57 PM
Posts: 166 California
Hotlumpy
California
did you blow out the passage in the main body? is the check needle below the squirter stuck?
Couldn't get air to go through the main body passage, how would I chesk the needle below the squirter? I'm pretty new at the insides of this carb.
[Re: RapidRobert]
#982629
04/29/11 07:40 PM
04/29/11 07:40 PM
Hotlumpy
California
Take out the big phillips screw and the squirter then turn it upside down to get the brass needle out and there is a gasket under the squirter
So now I have this needle out, then blow out the passages aqain & re-install?
[Re: Hotlumpy]
#982630
04/29/11 11:50 PM
04/29/11 11:50 PM
dartman366
Mt. Vernon, Ohio
after taking the needle out then use carb cleaner and blow thru it and make sure it is clear then inspect the needle for damage or sign's of rust or corrosion, those needles weren't always brass some were steel, also make sure the holes in the squirter are clear, take a small wire slightly smaller that the holes and run the wire thru them to make sure there isn't any debris in them.
[Re: Magnum]
#982632
04/30/11 11:33 PM
04/30/11 11:33 PM
Posts: 176 Rome, GA
GTXX
Rome, GA
Try it without the squirter nozzle and check valve in place.
if you do this, lay a rag in the carb to catch the check valve
