65 dart chrome trim removal how to?? #982292
04/28/11 10:37 PM
04/28/11 10:37 PM
RapidRobert Offline OP
Need to swap trim to a new 65 dart. No exp w this & seems like it's flush w the body. How do I get it off/up? I have the arrow shaped flat tool but I see no room & even if there was I'm not sure how to do it. Any advice/direction would be greatly appreciated.
Re: 65 dart chrome trim removal how to?? [Re: RapidRobert] #982293
04/28/11 11:29 PM
04/28/11 11:29 PM
central illinois
65dodgebob Offline
65dodgebob  Offline
central illinois
i just removed all trim from my 65 coronet 440. most of the trim on the sides of the car is held on with small nuts accessible from backside of door, fender, etc. open your trunk and check for either nuts or sometimes they used clips that push into holes like door cards are retained. sometimes you will need to remove any inner fender panels to access nuts. spray with penetrating oil first.
Re: 65 dart chrome trim removal how to?? [Re: 65dodgebob] #982294
04/28/11 11:33 PM
04/28/11 11:33 PM
Some of this trim is on the roof ect so it comes off from the top but just doesn't seem like much room to get up underneath it & not sure which way to gently pry it once I do & w what tool. It looks tight/I'm lost
