Re: 440 oil question
[Re: GregY]
#982260
04/28/11 09:39 PM
04/28/11 09:39 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thanks guys.
I am not a mechanic if you haven't already guessed. Could somebody take the time to give me a fairly detailed description of how to prime it with a drill?
I'm no mechanic either but go to TDC. Turn over 1/4 prime, trun 1/4 prime turn prime....should be good by then
[Re: Mr.Yuck]
#982261
04/28/11 09:42 PM
04/28/11 09:42 PM
Posts: 1,194 Rochester, New York
GregY
Rochester, New York
Thanks guys.
I guess what I am asking is how do you use a drill to spin the oil pump I have to pull the distributer I think. What do I use to connect my drill to whatever I connect it to. I hear people talk about it all the time, but I have never done it.
[Re: GregY]
#982264
04/28/11 09:55 PM
04/28/11 09:55 PM
Posts: 21,814 Kirkland, Washington
Pacnorthcuda
You're getting bits and piece of advice.
IF you want to manually prime; You need a long piece of 5/16 hex stock, you probably DONT have that laying around.
Position the damper mark at TDC on compression stroke Remove Dist cap, and note position of rotor--points to #1 cylinder. Remove dist. Document the position of the slot on the Intermediate shaft--where does it point? Remove Int shaft--long needlenose, twist it out. Insert hex stock down into oil pump. run drill Counter clockwise. You have to reposition the motor while doing this, or drill, reposition, drill etc till you confirm oil everywhere.
Return motor to TDC on comp stroke Replace Int shaft pointing same way. Replace dist point same way. Retime distributor.
But considering 3/4 of your heads are already getting oil, based on your OP, I would think your OK.
You COULD just remove the plugs and spin the motor--it will spin MUCH faster! and thats a whole lot easier in this case.
[Re: GregY]
#982265
04/28/11 10:02 PM
04/28/11 10:02 PM
RapidRobert
Several ways 2 go. MP sells the 5/16" preoil tool, 5/16" hex rods used to b easy to find at hardware stores, If you have a junk inter gear/shaft grind the teeth down to the root on your bench grinder & deburr w the wire wheel & they're soft & only takes several minutes or can get a 3/8" round rod & grind down to a 6 sided 5/16" hex on the end to fit the pump w your bench grinder then deburr it w the wire wheel & doesn't need to b a perfect hex. Just my preference I would reduce the rod dia a bit & wrap some tape around it in the several inches where it's in the inter bushing. Turn it CCW and from Andy if it's a new build start w hand cranking to see if the pump is free but you're past that so chuck your drill on the end & hold it tight & the rod CENTERED in the bushing. When you feel it catch pressure just eyeball the shaft to see if it's oiling from front to rear
[Re: GregY]
#982267
04/29/11 07:56 AM
04/29/11 07:56 AM
Posts: 21,064 Niles , Ohio
therocks
Niles , Ohio
That and make sure you have a big drill.Small drill wont work.I use an old Craftsman 1/2 inch monster when I prime them.When the pressure builds it will want to twist the drill out of your hands.Rocky
Chrysler Firepower
