Cylinder Head rebuilt, DIY #982252
04/28/11 09:09 PM
04/28/11 09:09 PM
Northern Virginia
barracuda7 Offline OP
Northern Virginia
Im gonna rebuilt 906 head, 68 383. This is my first time rebuilt cylinder head. Does anyone know where can I get Rebuilt Kit?
Im thinking of using Driller (have reverse direction) hook to the new Valve and rotate it clockwise & counter-clockwise for better sealing, will that work?
Anyone did that at home, please share your knowledge, thank a lot!
Re: Cylinder Head rebuilt, DIY [Re: barracuda7] #982253
04/28/11 09:42 PM
04/28/11 09:42 PM
wellington ohio
68-scatpack-rt Offline
In thin ice
In thin ice
wellington ohio
with all due respect.....take the heads to a machine shop and have it done correctly. at bare minimum you need a good three angle valve job, check the deck surface for flatness (have them milled to clean if need be). check the guides for wear and a quality reassemble.
also have the machinist check the valve springs to see if they are fatigued.
good luck.
unions....the folks who brought you the weekend!
