383 Crank End Play.... #980998
04/26/11 04:13 PM
04/26/11 04:13 PM
New Port Richey, Florida
Wolfe440 Offline OP
Wolfe440  Offline OP
I'm messing with a center thrust crank bearing on a 383, does anyone make an oversize bearing to reduce the crank end play? I thought I read once its available. I got about .010 too much end play.
If available any sources?
Thanks,
Wolfe.
Re: 383 Crank End Play.... [Re: Wolfe440] #980999
04/26/11 07:29 PM
04/26/11 07:29 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
.010 too much, or .001? Considering spec is .007, ten thou over that is a bunch.
One thou over? I probably wouldn't sweat it.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 383 Crank End Play.... [Re: 471Magnum] #981000
04/26/11 07:31 PM
04/26/11 07:31 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Another comment. 383 forged cranks are a dime a dozen. If you are that much over, just find a different crank.
-Jim
Re: 383 Crank End Play.... [Re: Wolfe440] #981001
04/26/11 07:38 PM
04/26/11 07:38 PM
Thanks,
Wolfe.
Check the thrust surface on the crank, if it is not smooth now what do you think it will do to a new main bearing, stock or oversize You need to find out, if it is not smooth, what caused the damages and fix that before replacing the center thrust bearing
Re: 383 Crank End Play.... [Re: Cab_Burge] #981002
04/26/11 07:53 PM
04/26/11 07:53 PM
Florida STAYcation
dIc dOc Deity ! Online penguin-006
The village idiot's idiot
dIc dOc Deity !  Online Penguin-006
Florida STAYcation
x 2 on not sweating 10 ....uNless you have a heavy pressure-plated stick-car.
Re: 383 Crank End Play.... [Re: 471Magnum] #981003
04/26/11 09:56 PM
04/26/11 09:56 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
Its defiantly .010. Total is .019, I would even settle for .009. In fact it must have been running for a while that way, engine was rebuilt in 2000 by the last owner and I can't see or believe it wore that fast, I don't think they checked it. We pulled the motor for other reasons. While out I dropped the pan to look things over and that's when I found it. It looks like a new crank is needed. I called around for an oversize bearing and was told to talk to King Bearing, they sometimes have unique offerings with bearings. Yet to do this.
Likely a new crank will be my only option as someone suggested. It can't obviously stay this way.
Re: 383 Crank End Play.... [Re: Wolfe440] #981004
04/26/11 10:19 PM
04/26/11 10:19 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
So it's .019 with a new thrust bearing or the one put in 2000? If with the old bearing,I'd try a new one....could be crank end-play was never set in 2000,causing accelerated wear on the thrust bearing.
Re: 383 Crank End Play.... [Re: Dcuda69] #981005
04/26/11 10:30 PM
04/26/11 10:30 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
I already got a new one, had to buy the whole darn crank main bearing set to get it. I put it in and took measurement. Hardly any difference between the old one and the new one, the new one gives me approx .002 less play and brings it down to .017.
Re: 383 Crank End Play.... [Re: Wolfe440] #981006
04/26/11 10:37 PM
04/26/11 10:37 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Ok makes sense now. Stick or auto? Looser than I'd like for sure. Sounds like oversize bearing(I've never seen or used one?) or crank time.
Re: 383 Crank End Play.... [Re: Dcuda69] #981007
04/27/11 12:48 AM
04/27/11 12:48 AM
Wolfe440 Offline OP
Wolfe440  Offline OP
Its an auto, 70 roadrunner convertible with A/C. Its rarely thrashed, mostly cruising mileage.
