Leak down test question #980678
04/25/11 10:26 PM
04/25/11 10:26 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Guys,
I am going to do a leak down test on the 440 in my Charger.
I am pretty sure I will be rebuilding or replacing the heads.
My question is this: can I just take the rocker arms off to close the valves instead of trying to get TDC on each cylinder as I test it?
Or do the other valves need to be in their relative positions as I test each cylinder?
Thanks.
Greg
Re: Leak down test question [Re: GregY] #980679
04/25/11 10:32 PM
04/25/11 10:32 PM
can I just take the rocker arms off to close the valves instead of trying to get TDC on each cylinder as I test it? yes
Or do the other valves need to be in their relative positions as I test each cylinder? no
W both shaft assy's off just look at like you are (in effect) sealing up the top of each individual cyl for 8 seperate individual tests
Re: Leak down test question [Re: RapidRobert] #980680
04/25/11 10:48 PM
04/25/11 10:48 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Cool, thanks Robert. I thought it would work, I just wanted to be sure.
