Re: 89 caravan bad tps?
[Re: 269charger]
#979917
04/25/11 08:49 AM
04/25/11 08:49 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Usually if hard codes the check engine light will be on.Have a place like Advanced check codes as they do it free.If no codes you might have to have a shop actually scan it and see what the sensors are doing.Just guessing gets costly.Those also had bad injectors.It also could be a bad oxygen sensor.TPS usually creates a stumble and or high or low idle.Rocky
Chrysler Firepower
