Re: Question on the stage V hemi 440 heads
[Re: waspnest69]
#979309
04/29/11 08:28 AM
04/29/11 08:28 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I agree with you Mr Yuck.I was only going this route to look..KOOL HAHAHA Not really interested in the HP,my cars are mostly yard ornaments as everyone calls them.I Love looking at them and get alot of pleasure in seeing what the real man has created with his own Muscle car...no matter what make.money isnt really a problem for me and I thank God for that.But I do appreciate what the normal average Joe makes with his dollars.Alot of guys go out and buy thier cars already done and havent turned a single bolt on it..What fun is that?
well then build ya a nice big hemi and drop a shiney huffer on top. Now that's eye candy! This one is in a 69 coronet.
[Re: waspnest69]
#979311
04/29/11 10:37 AM
04/29/11 10:37 AM
Posts: 74,962 U.S.S.A.
JohnRR
U.S.S.A.
Yeah I best just listen to The Mopar Guys.I was reading at one time that someone was producing the 440 block only with the siamese caps.Has anyone else heard about this? I will go with the 426 Block I get the point but still was curious as to what else is being made.Damn Man that Roadrunner of yours is growing on me!!!!!!What do ya have for a power plant?
Yes they make a wedge block like that but once again WHY buy that block then get the conversion heads, still have do all the mods even though that block is the exact same casting as the hemi block without the hemi machining and you still to buy a CUSTOM piston because a 440 at std bore is .070 larger than a hemi.
A Stock hemi intake will bolt to the conversion heads, don't know where you got that info.
[Re: Pale_Roader]
#979312
04/29/11 10:38 AM
04/29/11 10:38 AM
JohnRR
U.S.S.A.
I always wondered about a low-deck application for those heads... moot point, but still...
You can do a low deck with the conversion heads but you'll have to fabricate an intake manifold .
[Re: DaytonaTurbo]
#979315
04/30/11 03:03 PM
04/30/11 03:03 PM
Posts: 3,504 DFW
mr_340
DFW
I seem to recall those heads needed special rocker arms (exhaust side only?) to extend the pushrod towards the lifter valley. You might want to grind the pushrod clearance before doing the rest of the machining in case you grind into the water jacket and ruin the wedge block.
Floyd Lippencott IV
[Re: mr_340]
#979317
04/30/11 07:01 PM
04/30/11 07:01 PM
DaytonaTurbo
Manitoba, Canada
Ya they run special exhaust rockers. IIRC they are only 1.4 ratio as to move the pushrod far enough in.
[Re: waspnest69]
#979319
04/30/11 07:22 PM
04/30/11 07:22 PM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
heres there the way to drain heads back to pan see russel line hacked into block, if you dont do this motor will cavatate pan and hold all oil in heads and blow up(sweet). remember 440 block deck is not sqaured off and no huge 7/16 drain holes from deck top through block to all four oil pan corners like real hemi block...
MOPAR OR NO CAR
