Page 4 of 4 1 2 3 4
Re: Electric vacuum pump? [Re: Keith BlackĀ®] #977818
05/20/11 08:31 PM
05/20/11 08:31 PM
Eldridge, IA
HR5058 Offline
HR5058  Offline
Eldridge, IA
Moparacer,
Looks like you are using 10 or 12 line. I have enough of 8, will that work or do I need to go to 10 or 12?
Chuck
Re: Electric vacuum pump? [Re: HR5058] #977819
05/21/11 12:15 AM
05/21/11 12:15 AM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Moparacer,
Chuck
I used 12....
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Electric vacuum pump? [Re: HR5058] #977820
05/21/11 01:39 AM
05/21/11 01:39 AM
PA
moparacer Offline
moparacer  Offline
PA
Moparacer,
Chuck
Sorry so late but I think you should use -12 or 3/4 ID.
Need the CFM AT W.O.T.
sent you a pm.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Electric vacuum pump? [Re: moparacer] #977821
05/21/11 07:12 AM
05/21/11 07:12 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Ok here is how I rigged it up with my alky injection I just put on this past week.
First pic shows out of the front of the valve covers and don't forget to make sure they are baffled or it will suck oil when the engine is running.
Second pic is the breather setup I use to catch the moisture from the alky. I mounted the pump under the fender up front to save on space under the hood. The breather tube runs down through the hole where the battery tray was originally. As you can see the clear tubing is completely fogged up with moisture and water droplets with it running so its definatley pulling it out. Better off there then in the pan!
Last pic is the pump under the fender.
can you repost these pics ...I would like to see what you have done..thanks..
Page 4 of 4 1 2 3 4
