A100 oil pan #977137
04/20/11 09:37 PM
04/20/11 09:37 PM
MoPar Offline OP
MoPar  Offline OP
Does someone know what oil pan i should use in my A-100 truck, i'am putting a 340 in the original location where the slant 6 was, i do have a few different pans, but not sure what would be the best choice (front sump, rear sump or ??)
Re: A100 oil pan [Re: MoPar] #977138
04/20/11 09:39 PM
04/20/11 09:39 PM
scratchnfotraction Offline
rear sump truck pan IIRC
Re: A100 oil pan [Re: scratchnfotraction] #977139
04/21/11 01:42 AM
04/21/11 01:42 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
They used car pans, IIRC.
The 'truck' pans were for 72-later trucks.
Also, there isn't anything in the way under there, so you should be able to use any pan (with correct pickup).
http://www.youtube.com/watch?v=kcewnrO5vIc
http://www.youtube.com/watch?v=F3J-KeyDRZU
At 4:22 into the second one they show the oil pan.
Re: A100 oil pan [Re: RodStRace] #977140
04/21/11 09:07 AM
04/21/11 09:07 AM
i was thinking rear sump cause the front leaf spring axle,like most other chassis with leaf spring axle up front
