Re: 92 Shadow "No fan"
[Re: moparman111]
#977135
04/21/11 12:04 AM
04/21/11 12:04 AM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
If I run the car to town and back it should be warm enough to cause the fan to come on.
Not sure how far this town is but the length of the trip is not a good test for a fan on situation.
It's usually more of how long you've stopped driving for. During the trip, fans will not run because air flowing through the grille at speed will keep the radiator cool and your thermostat will regulate.
When you stop driving, or drive slow. Without the airflow through the grill. The thermostat will eventually go wide open. Next the temperature will rise and finally the fan will run to pull the temperature back down to almost thermostat temp.
If you have ac, cycle it. This will force the fan to run, regardless of engine temperature. If not, after a drive, let it idle. Depending on the weather, most cars will require fan after a 2 or 3 minutes.
[Re: buildanother]
#977136
04/21/11 09:24 AM
04/21/11 09:24 AM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
If its a 4 cyl start it.Then unplug the temp sender the fan should run.The relays are either on the ds fender or the firewall.Been a long time since Ive worked on one.There should be I believe 3 relays.Rocky
Chrysler Firepower
