easy way to center steering wheel? #977098
04/20/11 07:51 PM
04/20/11 07:51 PM
Minnesota
lukendan Offline OP
lukendan  Offline OP
Minnesota
I have a 1969 dodge charger. Is there an easy way to center the steering wheel without disconnecting the coupling?
Re: easy way to center steering wheel? [Re: lukendan] #977099
04/20/11 07:53 PM
04/20/11 07:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Depends on how far off it is. Most times the centering is done with adjusting the tie rod ends.
Re: easy way to center steering wheel? [Re: stumpy] #977100
04/20/11 08:05 PM
04/20/11 08:05 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
What Stumpy said.
In on one side tie rod assembly, out the same amount on the other side.
Shade tree approach using a tape measure to get the toe decent (~1/8" in total).
Down to just a blue car now.
Re: easy way to center steering wheel? [Re: 68HemiB] #977101
04/21/11 12:06 AM
04/21/11 12:06 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
A common practice but I'd want the each tie rod assembly to be about the same length as a priority.
Re: easy way to center steering wheel? [Re: lukendan] #977102
04/21/11 01:22 AM
04/21/11 01:22 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I thought that the steering coupler had a master spline that prevented it from going on wrong...?
I usually clock the tie rods to center the wheel.
Re: easy way to center steering wheel? [Re: Kern Dog] #977103
04/21/11 03:31 AM
04/21/11 03:31 AM
Riverside, California
ghostrider Offline
ghostrider  Offline
If the tie rods don't center it with minimal turning then the pitman arm was installed while the steering gear wasn't centered (that means with the wheels turned instead of straight ahead).
Must remember... my humor doesn't work on forums.....my humor doesn't work on forums. Former Mopars include 69 Super Bee, 71 Sebring, 68 Charger, 69 Charger, 78 D150, 67 300, 71 Road Runner clone, 79 T-top Doba, 67 Barracuda, 91 TC by Maserati, 68 Town & Country
