Re: Dodge Ram Troubles
[Re: Byellow Runner]
#97656
07/31/08 02:37 PM
07/31/08 02:37 PM
Posts: 105 Mid South, Tennessee
Byellow Runner
no suggestion?? I did for get to mention that is also takes longer to shift from 1st to 2nd. I can see maybe a sensor for the ABS giving a fault code which in turn would cause the brake light to remain on also.... But it seem strange that the speedo all of a sudden not working until I hit about 28-30mph and the tranny not wanting to shift until higher rpm. It seems the speedo and tranny shift problem are not related to each other. I can cause the tranny to shift at lower RPM by lifting on the throttle a little. Where as the speedo will not work until a certian spped. I also notice it is a little erratic between 30-40mph and after that is ok. And when I slow down to 30 or below it just drops down to zero as if the power was shut off. I guess they can all be unrealted problems that all happened at the same time. But seem funny that I drove to work no problems, then 6 hours later start the truck and now all this happens. ---any Dodge Dealer mechanics that have seen this before. I have a handy dandy Haynes repair manual but we all know what that is worth. Any suggestions would help. This happened last night and have not had a chance to take to a dealer.
Sorry just saw the reply.. I thought about that. The handy dandy haynes mentioned tha with Rear ABS (RWAL) the the sensor is mounted on the diff housing.
[Re: Dartsport540]
#97659
07/31/08 03:59 PM
07/31/08 03:59 PM
Byellow Runner
Would the speed sensor cause all these problems? I can see the ABS and Brake faults. Does the Speedo and Trans get speed input from that sensor also.
"Never argue with an idiot; they'll drag you down to their level and beat you with experience." ~ anonymous
69 Runner 440 stroker
72 Scamp waiting for a BB
96 Indy Ram
00 2500 Sport Ram V10
#97662
07/31/08 10:22 PM
07/31/08 10:22 PM
Posts: 1,113 Lost in Pooler, GA
Gumbydammit
Lost in Pooler, GA
Do it soon. My 99 speed sensor went and I drove it for a week like that. Next thing I know, the trans wouldn't shift out of first. New trans and speed sensor. Thank you WARRANTY !
I'm Gumby dammit!
