Dodge Ram Troubles #97654
07/31/08 01:27 PM
07/31/08 01:27 PM
Mid South, Tennessee
Byellow Runner Offline OP
Last night after getting off work I started my truck and the Brake light, ABS light stayed on and I noticed when I drove home the speedo will not work until I get to 28 mph. Anyone have any suggestions as to the problem. I have not done any recent work on the truck.
The vehicle is:
2000 sport Ram 2500 long bed 2wd V-10
Re: Dodge Ram Troubles [Re: Byellow Runner] #97655
07/31/08 02:26 PM
07/31/08 02:26 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
Probably the speed sensor in the rear diff. its a cheap and easy (guess) repair, I would start there.
Re: Dodge Ram Troubles [Re: Byellow Runner] #97656
07/31/08 02:37 PM
07/31/08 02:37 PM
no suggestion?? I did for get to mention that is also takes longer to shift from 1st to 2nd.
I can see maybe a sensor for the ABS giving a fault code which in turn would cause the brake light to remain on also.... But it seem strange that the speedo all of a sudden not working until I hit about 28-30mph and the tranny not wanting to shift until higher rpm. It seems the speedo and tranny shift problem are not related to each other. I can cause the tranny to shift at lower RPM by lifting on the throttle a little. Where as the speedo will not work until a certian spped. I also notice it is a little erratic between 30-40mph and after that is ok. And when I slow down to 30 or below it just drops down to zero as if the power was shut off.
I guess they can all be unrealted problems that all happened at the same time. But seem funny that I drove to work no problems, then 6 hours later start the truck and now all this happens.
---any Dodge Dealer mechanics that have seen this before. I have a handy dandy Haynes repair manual but we all know what that is worth. Any suggestions would help. This happened last night and have not had a chance to take to a dealer.
Sorry just saw the reply.. I thought about that. The handy dandy haynes mentioned tha with Rear ABS (RWAL) the the sensor is mounted on the diff housing.
Re: Dodge Ram Troubles [Re: 10sec440] #97657
07/31/08 03:32 PM
07/31/08 03:32 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I have replaced a few of them.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Dodge Ram Troubles [Re: 10sec440] #97658
07/31/08 03:36 PM
07/31/08 03:36 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
metal dust collects on the sensor and throws the sensor voltage reading off.
Re: Dodge Ram Troubles [Re: Dartsport540] #97659
07/31/08 03:59 PM
07/31/08 03:59 PM
Would the speed sensor cause all these problems? I can see the ABS and Brake faults. Does the Speedo and Trans get speed input from that sensor also.
"Never argue with an idiot; they'll drag you down to their level and beat you with experience." ~ anonymous 69 Runner 440 stroker 72 Scamp waiting for a BB 96 Indy Ram 00 2500 Sport Ram V10
Re: Dodge Ram Troubles [Re: Byellow Runner] #97660
07/31/08 04:02 PM
07/31/08 04:02 PM
N
NITROUSN Offline
NITROUSN  Offline
N
How else can the computers know how fast the rear wheels are turning.
Re: Dodge Ram Troubles [Re: NITROUSN] #97661
07/31/08 04:15 PM
07/31/08 04:15 PM
True... I went to Napa online and they have a sensor at a store close to me. Cost is $37.39. Sound like a good inexpensive fix. Thanks ya'll for the help. This could have been a factor if I would be able to take my Runner to the NATs this year. Thanks agian...
Re: Dodge Ram Troubles [Re: Byellow Runner] #97662
07/31/08 10:22 PM
07/31/08 10:22 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Do it soon. My 99 speed sensor went and I drove it for a week like that. Next thing I know, the trans wouldn't shift out of first. New trans and speed sensor. Thank you WARRANTY !
I'm Gumby dammit!
Re: Dodge Ram Troubles [Re: Gumbydammit] #97663
07/31/08 10:46 PM
07/31/08 10:46 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I had the same prob in my 01 Ram. it was the sensor. a few months after I changed the sensor
I also had the sure grip spring washer break and deposit a ton a crap inside the rear end..
