need help with wiper arms #976052
04/18/11 08:58 PM
04/18/11 08:58 PM
topeka,ks
dart_451 Offline OP
dart_451  Offline OP
topeka,ks
hi,can someone tell me how to get the wiper arms off my 41 plymouth s/delux? thanks for any help. loren
Re: need help with wiper arms [Re: dart_451] #976053
04/20/11 10:53 PM
04/20/11 10:53 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
On my 48 coupe, there is a little clip under the arm that covers part of the drum. You pull that little clip towards the end of the arm (away from the drum) and lift the arm off the drum. Sometimes you have to pry the arms up a bit to get them to move, just be sure the drum lock clip clears the drum.
My 50 truck has a nut on the top of the arm. You use a 3/8" wrench to loosen the nut and the arm usually lifts off.
I presume you have one of these 2 attaching methods, otherwise I guess I need to see a picture of your arms. Gene
Re: need help with wiper arms [Re: poorboy] #976054
04/22/11 05:16 PM
04/22/11 05:16 PM
topeka,ks
dart_451 Offline OP
dart_451  Offline OP
topeka,ks
thanks, i will try pullin the clip. iv tryed everything else i can think of. thanks agin.
